RX Instability Type 2 for a frame with bar releases defined in pinned supports
peterkamal91
peterkamal91
Dears,
-I have modeled a steel structure stage, after calculations i have got some instabilities (Type 2) in Rx which i couldn't recognize the reason of these instabilities -Could any one help me?
-I will attach the RSA file
@peterkamal91 Artur Kosakowski edited the topic for better findability
Artur.Kosakowski
Autodesk Support
Autodesk Support
I have blocked RX in the definitions of supports and in the 3 supports where you have bars with releases.to prevent rotations of bars about their own axes. You may check values of MX in bars and RX in these reactions and adjust releases (e.g. use a partial ones) where needed.
Artur Kosakowski
peterkamal91
-Thank you very much for reply & help Artur. every thing is O.K
-but I want to know the reason for that instability for that certain point ?! I mean there are similar points and there isn't any problem in it.
-I will attach the model again.
- The problem was in node no. 1245
Artur.Kosakowski
Autodesk Support
Autodesk Support
The solver may not report all of them at once however when you correct one location the next one will be reported when you calculate a model again.
Artur Kosakowski
