hi @HoshangMustafa
I understand that you are looking to match imposed or minimum reinforcement with tabulated results per floor.
There are many examples here on how to work with graphical results (reinforcement maps).
Your program may expand rapidly, quickly reaching several thousand lines of code, including graphical results, overlays, formatting, and more. What you're trying to achieve has likely been done many times by other users and companies.
As I mentioned, the forum is based on voluntary participation.
You need to refine your software architecture and code structure, set clear boundaries, and ask more targeted questions by theme.
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
