RTRKK profile database almost empty (ARSA 2015)
Jummybear
Jummybear
There is a small "war" is going after installation of ARSA 2015. Some things are already fixed, some not.
I found that RTRKK database in Robot 2015 is almost empty. Can I fix that? Printscreens included.
Rafal.Gaweda
Autodesk Support
Autodesk Support
There are no angles in Rautarukki database.
Click on first icon from the left on Standard tab
Rafal Gaweda
Jummybear
Unfortunatelly pressed as accepted as solution, but actually its still not.
In previous versions of Robot I had angles, IPE/HEA, C shaped profiles and so on. Now I have only 3 types: Round section, square section and rectangular section. At the same time Suomi (Finland) database has all of them and as I know finland database should be the same as RTRKK database, or am I wrong?
Rafal.Gaweda
Autodesk Support
Autodesk Support
I am afraid you are wrong:
Rafal Gaweda
Jummybear
I repeat once more: finnish profile database is based on ruukki profiles. You confirmed that here: http://forums.autodesk.com/t5/robot-structural-analysis/is-it-possible-to-update-renew-profile-datab...
Here you can download Ruukkii profile catalogue http://www.ruukki.com/Steel/Stock-products-and-prefabrication-services--catalogue
And there all mentioned above profiles listed: IPE, HEA, angles, C sections and so on. I can download and attach this catalogue to the next my post if you want, it weights 8mb 😃
Rafal.Gaweda
Autodesk Support
Autodesk Support
I think I miss something or you did not understood me.
My intention was to tell you that there are NO such families in Robot Rautaruukki database
because :
Rafal Gaweda
Rafal.Gaweda
Autodesk Support
Autodesk Support
The families you are lookig for are located in standard european database:
Rafal Gaweda
