Hi
I am trying to run a moving load analysis but the Moving Load option is greyed out (see attached screenshot).
Any ideas on how to fix this?
Best regards
Jonathan
Solved by Max-88. Go to Solution.
Start with a structure then add loads. I noted for an empty model the moving loads option is greyed out.
If that doesn't help, try to access the moving loads via the moving loads button in the Structure Definition toolbar - the button showing a red truck 😉
https://forums.autodesk.com/t5/robot-structural-analysis-forum/moving-loads/m-p/9180230#M79111
Rafael Medeiros
