RSA: I_DMDDDT_DEFL_Z_FROM_LIVE_LOADS - Runtime error / API
deligny-sa
Message 1 of 10
deligny-sa
I have problem with VBA;
RSA blocks at the line : RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z_FROM_LIVE_LOADS, 300
Here is the example:
Private Sub TEST_Click()
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "NF EN 1993-1-1:2005/NA:2013/A1:2014"
Dim RLabel As IRobotLabel
Dim RdimLabelData As IRDimMembDefData
Dim RDimMembParams As IRDimMembParamsE32
Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "TYPE_1")
Set RdimLabelData = RLabel.Data
RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200
RdimLabelData.SetDeflectionYZ I_DMDDDT_DEFL_Z, 1
RdimLabelData.SetDeflectionYZ I_DMDDDT_DEFL_Z_FROM_LIVE_LOADS, 1
Set RDimMembParams = RdimLabelData.CodeParams
RdimLabelData.CodeParams = RDimMembParams
RobApp.Project.Structure.Labels.Store RLabel
Set RLabel = Nothing
End Sub
Thanks for your help
Accepted solutions (3)
Replies (9)
Message 2 of 10
Stephane.kapetanovic
hi @deligny-sa
The criteria for member deflection from live loads are not set by the SetDeflYZRelLimit method of the IRDimMembDefData interface, as they are for final deflection and checkboxes.
Instead, they can be set by the RelLimitdeflUz property of the IRDimMembParamsE32 interface.
  Dim RLabel As IRobotLabel, RdimLabelData As IRDimMembDefData, RDimMembParams As IRDimMembParamsE32
  With RdimLabelData
    Set RDimMembParams = .CodeParams: RDimMembParams.RelLimitdeflUz = 300
  End With
You can refer to the example titled: APi - steel design - Activate deflection limit
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 10
deligny-sa
Thank you, it's perfect.
Message 4 of 10
deligny-sa
I get the total arrow with "RDmDetRes.UZ"
How to get the instant arrow?
I can't find the code.
BD
Message 5 of 10
hi @deligny-sa
Are you planning to use a set of combinations that exclude the permanent load cases? If so, the same approach can be applied in a second phase.
Best Regards
Message 6 of 10
deligny-sa
I wrote the code to deduce the permanent arrow from the total arrow
it works.
BD
Message 7 of 10
m11105821
I am working in cpython3,
I found similar problem, where the z deflection from live loads is not filled.
The Cpython3 code i wrote is below:
lbl = IRobotLabel(labels.Create(IRobotLabelType.I_LT_MEMBER_TYPE, "Adj_Member"))
lblData = IRDimMembDefData(lbl.Data)
lblData.Type = IRDimMembDefType.I_DMDT_MEMBER
lblData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 600)
lblData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z_FROM_LIVE_LOADS, 600)
lblData.SetDeflectionYZ(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 1)
lblData.SetDeflectionYZ(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z_FROM_LIVE_LOADS, 1)
Thanks in advance.
Message 8 of 10
hi @m11105821
read message 5 first :  https://forums.autodesk.com/t5/robot-structural-analysis-forum/rsa-i-dmdddt-defl-z-from-live-loads-r...
Message 9 of 10
m11105821
Hi @Stephane.kapetanovic
I have read and already tried to modify to cpython3 code, below is the code:
RDmServer = IRDimServer(robapp.Kernel.GetExtension("RDimServer"))
RDmServer.Mode = IRDimServerMode.I_DSM_STEEL
#lblData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z_FROM_LIVE_LOADS, 600)
param = lblData.CodeParams
param.RelLimitdeflUz = 500
However, 500 is not generated at all in my RSA.
Message 10 of 10
did you forget something ?
param = IRDimMembParamsE32(lblData.CodeParams)
lblData.CodeParams = param
