RSA display on high-resolution monitors (4K)
okapawal
Autodesk Autodesk
Message 1 of 1
okapawal
Hello, from the development team.
We want to improve RSA display on high-resolution monitors.  We know there are issues with icons, dialogs or tables in RSA on 4K monitors.
We would like to collect feedback concerning these issues.  Could you please paste a screen snapshot if you encounter the problem?  This will allow us to identify all the places to be corrected in the program.
Finally, we can give a hint for Windows 10 users.  If you set the compatibility mode to Override DPI scaling than the program works well on high-resolution monitors.
How to do it?
  • Click right mouse button on the RSA shortcut on your desktop
  • Choose Properties from the context menu
  • Switch to the Compatibility tab
  • Turn on Override high DPI scaling behavior checkbox
  • Select System form the drop-down menu
  • Accept setup with OK button
  • Run the program, it should be better now!
Waldemar Okapa
Sr Product Owner
Replies (0)
