[Revit<->Robot] Required member reinforcement issue
RRufino
RRufino
Hello all,
On a robot model that became originally from Revit i'm geting, on required member reinforcement module, this remark "member calculations for this type are not performed". The problem is that i've no issues in other beams with the same type and structure object definition.original.PNG
Also, i'm losting confidence on this model because when i open it in repair model it looks like this:
Please see file here.
Thanks in advance,
RR
RRufino
I found out why the issue with required reinforcement module happens and it seems me a terrible problem about Revit/Robot interoperability. The "red" beams have same section name (aka label) that some columns (0.25x0.50) but i remind that the first ones are "structure object = beam" and the second ones "structure object = column...even so, on sections menu only appears rc column with this section. I conclude that required reinforcement module is looking for this beams as being columns...
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @RRufino
For reinforcement design sections of a concrete beam should be defined using the RC Beam section type whereas for concrete columns you should use the RC Columns one.
The blue elements on the model opened in the repair mode are due to story filter being applied. When you switch it off you will 'see all the model'.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
