Hi, I have been noticing that RSA 2017 just shuts down suddenly in some of my models without even without showing the crash windows and unfortunatly i was not able to determine the cause of that. but I attached a file that did that twice now and when i open it in the repair mode and run it RSA crashes.
Solved by Rafal.Gaweda. Go to Solution.
Set SparseM solver for calculations then check
My file attached
Hi, I'm an Italian Robot user. I have the same "APPCRASH" problem with RSA 2017. I cleaned the HD with a virus scan, I unistalled RSA and then reinstalled it without success. At present my personal workstation can't even begin to load RSA.
Thanks for help
Monica
Monica
- Unistall Robot
- clear registry (find and delete all entries with numbers in brackets):
SET I_PRODUCTCODE={45E99851-575B-4C07-9ECC-8DB98AD9A2FD}
SET I_PRODUCTCODE_EN={210F2780-8F2E-4F63-95F5-D134BFB4B1D8}
SET I_PRODUCTCODE_PL={8FA02B00-5AF2-4285-9AB0-8CB50298ECE3}
SET I_PRODUCTCODE_FR={C3BE429F-61E7-4BC1-A7FC-DE4BA67AE5AE}
SET I_PRODUCTCODE_IT={276B4941-F9EE-4C46-BAD7-6B5D6F92E3EE}
SET I_PRODUCTCODE_JP={6A99722D-B88C-4066-96A8-6B3990BB080B}
SET I_PRODUCTCODE_RU={D9D5E78A-9E53-4837-B49D-E89BDAEACBA8}
SET I_PRODUCTCODE_SP={230FA552-890B-4628-AE82-86283545EDAF}
SET I_PRODUCTCODE_PT={33AA8AEC-C1F2-41F0-8F31-F21B8A7CA417}
SET I_PRODUCTCODE_DE={17A6A5A6-E479-4CD2-9B8C-3F0B8102FAA6}
SET I_PRODUCTCODE_ZHCN={70FC4CFD-ED0E-40DE-8173-CBBB09EBA0B8}
- clean windows %temp% folder
- clean robot CFGUSR folder
- restart coomputer
- install Robot
- in case of similar crash please use SparseM solver
Hi, I tried to follow the instructions you gave me, without success. Actually I tried several times and I noticed an error even during Robot installation.
What is SparseM solver?
Monica
