Rounding up coordinates (API)
46 REPLIES 46
Message 1 of 47
Rafal.Gaweda
8648 Views, 46 Replies
I am attaching small addin (private, not ADSK) for rounding up coordinates in Robot
You can add it to add-ins menu:
- as dll (the fastest method of getting results from robot) basing on dll_1.zip from this thread starting from point 13
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Creating-DLL-for-API-and-making-it-available...
- as exe
or by running exe
It seems to work OK.
Rafal Gaweda
46 REPLIES 46
Message 21 of 47
Okay, I will make it. Also I will try to make installer with selecting language.
Message 22 of 47
Unfortunately I don't see any localization resources in project inside RoundUpDown_2lang.zip
I can make it myself but it's will be more simply with ready resource.
Message 23 of 47
My mistake.
Correct project attached.
Rafal Gaweda
Message 24 of 47
That okay.
Message 25 of 47
I made it, check please
Message 26 of 47
mgaafar
in reply to: Rafal.Gaweda
Rafal, I found small bug, it seems there is rounding error or defining data. in my case the numbers were ok but the new rounded numbers contained extra decimal.
Tags (1)
Message 27 of 47
Rafal.Gaweda
in reply to: mgaafar
Try this one.
If still not correct please send me at least part of this model with these nodes.
Rafal Gaweda
Message 28 of 47
mgaafar
Thanks Rafal, the bug is fixed and it is working fine now.
Message 29 of 47
mgaafar
Sorry Rafal, I found something else that is not consistant.
Roundup2.jpg: Y-coordinate at last point was rounded up but the other ordinates changed from 10.210000 to 10.22 while the tolerance is only 0.01?
http://www.screencast.com/t/2Fe2nxr1M5L
Please review, also may be it will be more useful if "Other objects" deal with rounding structural axis coordinates as well.
thank you very much for your help.
Message 30 of 47
Rafal.Gaweda
INteresting.
Please send me such robot file.
Rafal Gaweda
Message 31 of 47
mgaafar
here you are
Message 32 of 47
mgaafar
Maybe this link can help figuring out the approximation error.
http://www.theregister.co.uk/2006/08/12/floating_point_approximation/
Message 33 of 47
Rafal.Gaweda
More less this wqas the problem
According to our processors 10.21*100000 = 1021000,00000001
Correction in attachment
Rafal Gaweda
Message 34 of 47
t.sautierr
Can you post the .exe file please ..;
Thanks a lot.
I am not familiar with  Csharp express etc ..
Message 35 of 47
Rafal.Gaweda
in reply to: t.sautierr
It was wrong attachement.
Check again attachment in previous message.
You are fast 🙂 It took me one minute to replace attachment and in the mean time you downloaded it.
Rafal Gaweda
Message 36 of 47
This add-in is awesome!
Saves a lot of time with sloppy users 😉
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 37 of 47
I wanted to round to 0,05m so I had to make some changes to your code (to ToDec function), if you don't mind.
Maybe you're interested:
private double ToDec(double numberToTruncate)
double roundingVal = 1;
int numOfDecimals = 0;
	if (TolcomboBox.SelectedItem != null) {
		string text = TolcomboBox.SelectedItem.ToString();
		if (text.Length > 1) numOfDecimals = text.Length - 2;
		roundingVal = Convert.ToDouble(text);
        numberToTruncate = Math.Round(numberToTruncate, 9);
	double power = Math.Pow(10.0, (double)numOfDecimals);
        if (radioButton1.Checked)
	return Math.Round(Math.Floor(numberToTruncate / roundingVal) * power, 0) * roundingVal / power;
        else
	return Math.Round(Math.Ceiling(numberToTruncate / roundingVal) * power, 0) * roundingVal / power;
Function now can be used to round to any decimal value, for example: 0,25  😉
Cheers!
Mirko Jurcevic
Message 38 of 47
in reply to: Mirko.Jurcevic
Hi Mirko,
Do you have an exe file for your modified version of this code?
Would be greate to have it..
Regards
Janis
Message 39 of 47
Mirko.Jurcevic
Of course
Here, just change the extension to exe and add it to robot
Right click on the link and "save link as"
Mirko Jurcevic
Message 40 of 47
Thats great. Thanks a lot!
Regards
Janis
Technology Administrators
