Rounding up coordinates (API)
46 REPLIES 46
Message 1 of 47
Rafal.Gaweda
9809 Views, 46 Replies
I am attaching small addin (private, not ADSK) for rounding up coordinates in Robot
You can add it to add-ins menu:
- as dll (the fastest method of getting results from robot) basing on dll_1.zip from this thread starting from point 13
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Creating-DLL-for-API-and-making-it-available...
- as exe
or by running exe
It seems to work OK.
Rafal Gaweda
46 REPLIES 46
Message 2 of 47
Does this add-in applies to node coordinates only or contour panel points are also included in the rounding up?
Message 3 of 47
it will round up everything.
Rafael Medeiros
Message 4 of 47
in reply to: Rafal.Gaweda
Hello, Rafal
Thank you for the solution. Unfortunally, it doesn't work on my PC (not exe, nor dll). OS is Windows 7 x64, RSA 2013 SP1.
I have obtained this error (please, see file error.png)
Log of exe error in file LOG.txt
If you need any additional info, please, let me know.
Thank you in advance!
Message 5 of 47
Rafal.Gaweda
Igor,
Try this:
Start Command Prompt as Admin (from rigth hand mouse menu) then unregister and register robot exe as decribed here:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/VBA-Excel-macro-for-any-object-geometry-modi... - message 8/9
Rafal Gaweda
Message 6 of 47
Rafal, thanks a lot for your support!
Message 7 of 47
Rafal,
I have Robot 2012 and 2013 installed on my PC.  I installed your add in and it works OK on 2013, but when I try to use it on 2012 I get the following error......................
Is this because the add in is already "registered" to 2013?
Tony
Message 8 of 47
Rafal.Gaweda
Can be. Please register v 2012
(command line must be run in Admin mode: message 6 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-error/m-p/3518984/highlight/true#M5791)
Rafal Gaweda
Message 9 of 47
I downloaded the roundingup.zip nad run add-ins in robot , it listed on add-ins, but clicked it do not run.
Mike
Message 10 of 47
Rafal.Gaweda
Example movie: http://screencast.com/t/CFsS8hljU9Ik
Sometimes click twice on Round Up button
Rafal Gaweda
Message 11 of 47
Hi dear RG_Adsk
Can we develop some one-click installer for Robot addons?
I already have similar solution for Revit Add-In Installer
Need to replace tld.bat with automatic dll registration from installer.
Message 12 of 47
Yes, you can
Remember to register dll if you want to install dll
c:\Windows\Microsoft.NET\Framework64\v4.0.30319\regasm.exe /tlb /codebase roundup.dll
Rafal Gaweda
Message 13 of 47
Rafal.Gaweda
BTW: do you want it in your language version? If so - can you compile VS 2010 project?
Rafal Gaweda
Message 14 of 47
Yes, I know. I made my own tiny addon which create closest nodes between two uncrossing bars, very useful to link then by rigid links. I use you manual to prepare addon in Robot, thanks.
I already use you RoundUP, and I can translate it to russian (must be useful for some russian users).
I have one question for installer - how to find proper regasm in any computer?
For example
1) C:\Windows\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe /tlb /codebase
1) F:\Windows\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /tlb /codebase
Maybe some system variable?
Message 15 of 47
OK, I will prepare and send you VS project to translate
For example
As far as I remember for 32 bit system you can use ordinary regsvr32 ; for 64 ...Framework64\...\RegAsm.exe
Rafal Gaweda
Message 16 of 47
Rafal.Gaweda
Now - rounding Up or Down in attached exe.
Rafal Gaweda
Message 17 of 47
t.sautierr
Great ! works perfectly with RSA 2013 !
Message 18 of 47
YarUnderoaker
in reply to: t.sautierr
No work. I get a message box with "Robot not started" with opened Robot and without.
Path to my Robot F:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\robot.EXE
Message 19 of 47
Message 20 of 47
Rafal.Gaweda
Example movie how to make translation http://screencast.com/t/KRpXFwaoRf8
(Replace strings in Value column)
Rafal Gaweda
