Hi everyone
I want to visually see the result of my nodes(join) rotation (Rx,Ry and Rz ) instead of (ux,uy and uz) in RSA to see if i have thesame values as the theoritical results.
How Can i see the results please ?. Need your help.
Solved by EduardoMeruvia. Go to Solution.
If dealing with Panels then: Results --> Maps --> Rotations
If dealing with beams: Select Node, right click --> Object Properties --> Displacements Tab --> Rotations
Many thanks for the answers.
Also i want to manually enter the inertia of a bar or beam and don't want RSA to automatically calculate that for me. Is it possible to do that?
Creating custom section with manual Cross-sectional inputs is possible. See below.
Not sure if you seen this already, but recommend watching the Robot Webinar Series available in Youtube. Very useful resource to learn more about Robot.
https://www.youtube.com/watch?v=3G5NwyDSzxs&list=PLY-ggSrSwbZqow_60fiqJwS69mg1nQMzk
Yeah, Will surely follow these webinars as from thanks for the recommandations and help.
