Rotating rotor
Rotating rotor
dkien.mills
Message 1 of 13
Rotating rotor
dkien.mills
Hello members,
I am trying to declare a time function of a machine placed on one floor of my building.
I don't know which form of equation to enter to describe 3 phases of this vibrating load : start phase, constant phase and ending phase.
Someone could lead me ?
Many thanks.
Replies (12)
Message 2 of 13
Stephane.kapetanovic
hi @dkien.mills
https://knowledge.autodesk.com/support/robot-structural-analysis-professional/learn-explore/caas/sfd...
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 13
dkien.mills
Hi @Stephane.kapetanovic
actually I just watched these videos several times;
But The author did not show how to define this function with 3 phases, and that's my question.
Message 4 of 13
dkien.mills
Hi @Anonymous, actually I just watched these videos several times;
that's my question.
Message 5 of 13
Pawel.Pulak
Autodesk Support
Autodesk Support
the constant conditions of rotating machinery are described in this forum thread.
As concerns starting conditions, is linear increase of rotation frequency sufficiently precise for you?
In such case I can try to find some example I made years ago.
Pawel Pulak
Technical Account Specialist
Message 6 of 13
hi @dkien.mills
it is important to consider transient regimes. you can create functions even add them and also load or create a *.thf file
the points contained in the *.thf files can be obtained using a spreadsheet especially if your start and stop functions are not linear
Best regards
Message 7 of 13
dkien.mills
hi @Pawel.Pulak
thanks for your sms
My machine dryers runs from 0Hz to 5.75Hz and then constanly at 5.75Hz.
Like you said, I wanna model the transient and constant phases.
Message 8 of 13
dkien.mills
Re @Stephane.kapetanovic
thanks for your advice, yeah that's I wanne do. But I don't find anywhere the type of function in the transient regime.
if you ever have an exemple about it ?
Message 9 of 13
hi @dkien.mills
https://forums.autodesk.com/t5/robot-structural-analysis-forum/conversion-of-txt-or-excel-file-in-th...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/how-can-i-import-accelerograms/m-p/80...
Linear start function example
this type of curve depends on the type of start: gradual or direct, no-load or under load, etc.
Best regards
Message 10 of 13
In the case of a complete use you must have at least three functions: start, normal regime, stop.
Duration of normal regime is also function of your structure response to obtain all results.
You must "add expression" three times with different parameters
Function Start, beginning time = 0 , end time = duration(Start)
Function Normal, beginning time = End of Start, duration(Start + Normal)
Function Stop, beginning time = End of Normal, end time = duration(Start + Normal + End)
After that you can mixt between values from a file and formulas by adding expression
Message 11 of 13
dkien.mills
Thanks for your return
You answered my question. I have now an idea of the function at transient stage.
Message 12 of 13
Pawel.Pulak
Autodesk Support
Autodesk Support
Hi @dkien.mills ,
apologies for delay of my response.
Finally I have found the old example illustrating it which I made years ago.
It was necessary to translate to English the short doc with mathematical/mechanical explanations and comments in the test spreadsheet. All together (example model, doc and spreadsheet) are contained in the first attached ZIP.
This example discusses only the start of machinery and steady state (without stop) and neglects the increase of the amplitude of centrifugal force with the square of rotation frequency.
I have also found the model made several years later, used in the video linked above by @Stephane.kapetanovic
I have attached it to this post too.
Here both start, steady state and stop of machinery are considered, linear change of rotation frequency is assumed during start and stop, and the influence of rotation frequency on the centrifugal force is taken into account.
Unfortunately I have not noted the expressions of forcing functions - but it was easy to derive them again basing on doc I mentioned.
This model contains time history with linear increase of rotation frequency to 10 Hz between 0 and 4 seconds, then constant 10 Hz frequency between 4 and 8 seconds and then  linear decrease of rotation frequency from 10 Hz to 0 Hz between 8 and 12 seconds.
Here are the expressions to generate forcing functions for above conditions (for angles expressed in Radians):
"Force FY" excitation in "2_start and stop of rotating machine THA.rtd")
start 0=<t=<4
1/16*t^2*sin(10/4*3.1416*t^2)
steady state 4<t=<8
sin(2*3.1416*10*t)
stop 8<t-<12
-1/16*(t-12)^2*sin(10/4*3.1416*(12-t)^2)
"Force FZ" excitation in "2_start and stop of rotating machine THA.rtd")
start 0=<t=<4
1/16*t^2*cos(10/4*3.1416*t^2)
steady state 4<t=<8
cos(2*3.1416*10*t)
stop 8<t=<12
1/16*(t-12)^2*cos(10/4*3.1416*(12-t)^2)
Pawel Pulak
Message 13 of 13
dkien.mills
hi @Pawel.Pulak
thanks you for your return
it's very useful not only for me but also for other users.
