Rotating Column
Rotating Column
Rotating Column
I have modelled a circular shaped building, but my columns are not correctly aligned
Please can you advise how I would rotated my columns about their own axis so that the column webs are parallel with the grid line back to the centre of the building and the column flange is pointed away from the building.
Some are my columns are aligned correctly, as shown in the second image.
Thank you for your help.
Richard
Rafal.Gaweda
Autodesk Support
Autodesk Support
Try this
Or select node in the grid (circle) center
Rafal Gaweda
Of course.
Thanks for your help
