Rotate Foundations
Rotate Foundations
Rotate Foundations
Good day! I am actually new to Autodesk Robot.
I was designing an isolated footing and I wondered if I could rotate the footing similar to rotating elements using the "GAMMA" property. I want it to align to the inclined global axes.
Attachment: Footing at Node 32 will be aligned to inclined global structural axis (X2).
Thanks for the reply.
Simau
Hi @Anonymous
You may create a support with desired orientation
M. Agayr
