Hi All,
I am trying to improve the speed of extracting Robot results using the RobotResultQueryParams approach. I have read through all the posts but cant understand why RobotResultQueryParams always returns "I_RQRT_DONE". Here is my code:
//Set the selection for all finite elements RobotSelection FESelection = robApp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_FINITE_ELEMENT); FESelection.FromText("All"); //Set the selection for all load cases RobotSelection CasSelection = robApp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_CASE); CasSelection.FromText("All"); //set the selection for all panels RobotSelection PanSelection = robApp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_PANEL); PanSelection.FromText("All"); //set the selection for all nodes RobotSelection NodSelection = robApp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_NODE); NodSelection.FromText("All"); //Fast Method IRobotResultQueryReturnType Res; RobotResultQueryParams RobResQueryParams; RobotResultRowSet RobResRowSet = new RobotResultRowSet(); RobResQueryParams = robApp.CmpntFactory.Create(IRobotComponentType.I_CT_RESULT_QUERY_PARAMS); RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_MULTI_THREADS, true); RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_THREAD_COUNT, 4); RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_SMOOTHING, IRobotFeResultSmoothing.I_FRS_SMOOTHING_WITHIN_A_PANEL); RobResQueryParams.SetParam(IRobotResultParamType.I_RPT_LAYER, IRobotFeLayerType.I_FLT_MIDDLE); //RobResQueryParams.Selection.Set(IRobotObjectType.I_OT_FINITE_ELEMENT, FESelection); //RobResQueryParams.Selection.Set(IRobotObjectType.I_OT_PANEL, PanSelection); RobResQueryParams.Selection.Set(IRobotObjectType.I_OT_FINITE_ELEMENT, NodSelection); RobResQueryParams.Selection.Set(IRobotObjectType.I_OT_CASE, CasSelection); RobResQueryParams.ResultIds.SetSize(8); RobResQueryParams.ResultIds.Set(1, 501); //IRobotFeResultType.I_FRT_DETAILED_MXX RobResQueryParams.ResultIds.Set(2, 502); //IRobotFeResultType.I_FRT_DETAILED_MYY RobResQueryParams.ResultIds.Set(3, 503); //IRobotFeResultType.I_FRT_DETAILED_MXY RobResQueryParams.ResultIds.Set(4, 492); //IRobotFeResultType.I_FRT_DETAILED_NXX RobResQueryParams.ResultIds.Set(5, 493); //IRobotFeResultType.I_FRT_DETAILED_NYY RobResQueryParams.ResultIds.Set(6, 494); //IRobotFeResultType.I_FRT_DETAILED_NXY RobResQueryParams.ResultIds.Set(7, 519); //IRobotFeResultType.I_FRT_DETAILED_QXX RobResQueryParams.ResultIds.Set(8, 520); //IRobotFeResultType.I_FRT_DETAILED_QYY Res = robApp.Project.Structure.Results.Query(RobResQueryParams, RobResRowSet);
Problem is with the last line "Res =...."
Has anyone got any idea why this is as I have tried multiple combinations of selecting cases with elements, nodes and finite elements.
Thank you!
That's a good sign. 😀
Now, you have all the results and you need to go thru then like this:
Dim ok As Boolean
ok = RobResRowSet.MoveFirst()
If ok = False Then Exit Do
While ok
' do something with values and parameters
'RobResRowSet.CurrentRow.GetParam(I_RPT_PANEL)
'RobResRowSet.CurrentRow.GetParam(I_RPT_NODE))
'RobResRowSet.CurrentRow.GetParam(I_RPT_LOAD_CASE))
'RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(1)) * 0.001
ok = RobResRowSet.MoveNext()
Wend
regards
I was expecting that it should return "I_RQRT_MORE_AVAILABLE"?
This is because the rest of my code is like this:
while (Res == IRobotResultQueryReturnType.I_RQRT_MORE_AVAILABLE) { bool ok = RobResRowSet.MoveFirst(); while (ok) { numCas = RobResRowSet.CurrentRow.GetParam(IRobotResultParamType.I_RPT_LOAD_CASE); numFe = RobResRowSet.CurrentRow.GetParam(IRobotResultParamType.I_RPT_ELEMENT); res_nxx = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(1)); res_nyy = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(2)); res_nxy = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(3)); res_mxx = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(4)); res_myy = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(5)); res_mxy = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(6)); res_qxx = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(7)); res_qyy = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(8)); //write to file here
ok = RobResRowSet.MoveNext(); } Res = robApp.Project.Structure.Results.Query(RobResQueryParams, RobResRowSet); }
I have forced the code to jump into the while (ok) loop by manually overriding Res to equal "I_RQRT_MORE_AVAILABLE". But when I do this, the code breaks down on this line:
I get this error: "System.Runtime.InteropServices.COMException: 'Error HRESULT E_FAIL has been returned from a call to a COM component.'"
When I remove this line, the code executes perfectly! I want the line above to give me the finite element number.
On another note, the results come out in the following order: 1. load case 2. element. e.g.
Load Element Results...... 1 1 results here...
2 1 results here...
3 1 results here...
1 2 results here...
2 2 results here...
3 2 results here...
etc...
I want the results to be produced like this:
Load Element Results...... 1 1 results here... 1 2 results here... 2 1 results here... 2 2 results here... 3 1 results here... 3 2 results here... etc...
Thanks a lot!!!
In your first post if you get, if you get I_RQRT_DONE, then you already have all results. If you get I_RQRT_MORE_AVAILABLE then you get only a part of your results and you should call your function again to get the other part, and so on... see API manual that gives you this info...
I think it is not implemeted in API please see
Regarding order, I don't know how to control that (nor if there is a way). So after I get all the results (in a transient matrix for ex...) then I reorder as I want and finally put the results in the final place...
Sorry for not helping you more... regards
Thanks for the reply.
Surely there must be a way to get the finite element number for each of the results! Otherwise how do I know which finite element the results are for?
I’ll have to manipulate the results to get them into the right format then, which isn’t a problem.
"Surely there must be a way to get the finite element number for each of the results! Otherwise how do I know which finite element the results are for?" That's a good question for developers 😁. Maybe @Rafal.Gaweda can help you with this!
In this example, it is not a problem because you are asking results smoothed within panel, so you only need to know the node and the panel.
Regards
