Robot to SAP
Robot to SAP
Message 1 of 8
Robot to SAP
I need to convert a model done in Robot to SAP.
I remember seeing sth in the forum re that but can not find it at the momento. I think it was done via Revit?
Can anyone please help with this?
thanks very much,
sanjuan100
Replies (7)
Message 2 of 8
Also, can confirm what things are / are not lost in the process?
e.g.
bar sections
material properties
loading
releases
member type parameters (steel design)
Thank you
Message 4 of 8
thanks, would it be possible to be more specific?
I've done this search myself but there are many entries I can't find much information.
sanjuan100
Message 5 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
I wanted to show you how to use Search.
I do not know the answer for you.
Search for it.
Rafal Gaweda
Message 6 of 8
don't you have an answer?
My client uses SAP while we use Robot, they need to check our work and it'll be a lot easier if we can send a model of the structure. It must be a case that happens often?
Thanks in any case.
Regards
Message 7 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Upps, sorry.
The answer is : Robot is not capable to export model to SAP \ SAP file by its own.
Maybe there is plugin somewhere on the web doing that.
I am very sorry for misleading you.
Rafal Gaweda
Message 8 of 8
StefanoPasquini6790
I think that using revit as "import-export" hub can be the best solution. I'm sure that you will loose all the verification parameters for bars
If this don't work you can try with an sdf file, but in this case you will loose also the loads.
At the end, you can try via data table...
Good luck.
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
