Robot Supported Design Codes
jo2ny
jo2ny
Does Robot have support for ASME Codes ?
If not, will this be included in future versions?
Thank you,
Artur.Kosakowski
Autodesk Support
Autodesk Support
No, it doesn't. I'm sorry but we are not in the position to discuss any development plans on this forum.
Artur Kosakowski
In robot 2016, for Australia standard,it have AS1170-4 for earthquake but i didn't see AS1170-2 for Wind actions. is there any solution to apply wind actions? thanks
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may try to use the Wind Simulation tool or generate wind according to one of the implemented codes if acceptable. Otherwise you need to define the loads manually.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
