Robot Stuck in Calculations
albertobg028
albertobg028
Community Visitor
Community Visitor
Hi all,
I've been having some issues with a RSA model.
When a try to run all the load cases (about 300) it gets stuck in the LC 1, without any prompt. When a few cases are selected it goes through the process seemly (including LC 1).
Load Case 1 is Dead Load of the whole structure. It is a large model with a number of:
Members: 3900
Panels: 4600
Nodes: 94000
There are some "isolated nodes" and "incoherent mesh on edges" warnings/error that couldn't been solved, but the model didn't had any problem calculating before.
I tried to run the model using repair mode but the problem persists.
Stephane.kapetanovic
Hi @albertobg028O
It seems that the inconsistent mesh, if left unresolved, will prevent you from starting the calculations. Scanning your file may not be immediate.
Could you share your model?
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
