ROBOT STRUCTURAL SMALL DISPLACEMENTS/DEFORMED SHAPE
tovarog23
tovarog23
Hello!
I have been working on a steel structure model that I have already tested at other different structural analysis software (MIDAS Gen, ETABS) and for some reason, in the new 2022 RSA, when I run the model, the displacement values and deformed shape are almost non existent and way too small. I have a large cantilever that carries two levels, and, despite the fact that I was expecting to get a large value of deformation, the value turned out to be less than 1cm, without even using bracing and using very small steel sections. I have attached an image of the deformed shape which makes no sense. I have already checked everything and cannot find any error. I do get an instability of type 3 whenever I run the model, but not sure if that is somehow related.
Replies (8)
Stephane.kapetanovic
hi @tovarog23
Could you tell us your model ?
Best regards
tovarog23
The model is just consists of steel framing and cladding. Only secondary beams have pin-pin releases and all columns have a pinned support. In terms of loads, it has gravitational (Dead, Live) and a response spectrum analysis with 10% eccentricity for each direction. I would love to share the model in this platform, but not sure how to do it as files bigger than 71 MB are not allowed.
You can send download hyperlink.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @tovarog23
Save file as RTD without results than zip it. Then it should be small enough to attach it to forum post.
Krzysztof Wasik
tovarog23
Thanks for the advice, I have attached the model that I made.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi
You have used full stiffening (rigid body)  model for slab panels simulation. Change it to Partial stiffening (in XY).
Krzysztof Wasik
tovarog23
Thanks a lot! I initially thought that full stiffening would provide me a rigid diaphragm behavior, and that the partial diaphragm would be more of a flexible option. If I wanted RSA to consider a flexible diaphragm, what should I use?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @tovarog23
In this case you should use Partial stiffening (in XY)..
Krzysztof Wasik
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
