Robot Structural – Report shows all reactions instead of max per node
lgbWWSRT
lgbWWSRT
Hey everyone,
I’m having an issue with Robot Structural when generating the support reaction report. The report currently lists the reactions for every load case at every node, but what I actually need is just the maximum reaction per node for a chosen set of load cases.
Right now, the report is flooded with results from 400+ load cases, which makes it really hard to read. Does anyone know how to only display the maximum reactions (instead of each individual case) in the report?
Thanks in advance!
Stephane.kapetanovic
hi @lgbWWSRT
you can already choose the tabs available on the tables
you can also customize them
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
lgbWWSRT
Hi Stephane,
Great exactly what i need except for i still doessen't update when i'm doing it in the creation of the report. Do you know why?
Sincerely
Lauritz
Do you mean the tabs don't work?
lgbWWSRT
The tabs worked, but didn't change it in the report 😕
Sincerely
Lauritz Brask
