Hello all,
I am currently setting up various member definitions in Robot using API in VBA. I wish to know if there is any API code that will allow me to check and uncheck the blocks shown below in the Internal Bracing tab of member definitions.
I wish to be able to do this for all four of the tabs (Buckling Y, Buckling Z, Lateral buckling-upper flange, Lateral buckling-lower flange). I am working with SANS.
Thank you for any help.
Solved by Stephane.kapetanovic. Go to Solution.
look at these topics:
LTB & Steel Bracket, [API] Steel Code Params Buckling Diagram, [API] Define Membertype Adjoin Params
Here after an example
IRobotLabel Rlabel = Labels.Create(I_LT_MEMBER_TYPE, "SetOption_Adj_Member");
IRDimMembDefData MembDefData = (IRDimMembDefData)Rlabel.Data;
MembDefData.SetIntPtAddOption(I_DMDIPDT_BUCKLING_Y, I_DMDIPOT_IN_ADJ_MEMBER, 1);
Labels.Store(Rlabel);
Best Regards
