Robot Structural analysis
aashish
aashish
I have modeled four connected walls and applied earth pressure and vertical load on a point. Analysis model was verified and calculation was run. that was ok. When I tried to run Required reinforcement of RC slabs/Walls, a comment Incomplete result for panel number 1, similarly for all the panels was obtained. i couldn't find the reason. Could any one help me to sort this out. I tried with earth pressure alone then also the same problem was there.
Rafal.Gaweda
Autodesk Support
Autodesk Support
