Maps result legend not displaying full range
Message 1 of 8
Can someone tell me why the legend for does not display the full range of divisons? How can this be changed such that the full range is displayed?
Dane
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to change user defined to linear and press Apply.
Artur Kosakowski
Message 3 of 8
Hi Artur
This does not work, however, when the number of divisions for both linear and user defined is set to 14 the entire range shows.
Regards
Message 4 of 8
Try changing automatic scale to "complete palette".
Message 5 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach the file saved with the display as on the picture please?
Artur Kosakowski
Message 6 of 8
None of the suggestions above have worked.
I have attached a seperate example but the problem is still the same.
As previous the full range is shown for 14 divisions and below but not for 15 divisions and above. This stands for both user defined and linear scales.
Regards
Message 7 of 8
I seem to have managed to get the legend to show the full range by doing the following:
1. Applied the user defined scale (lengend shows range as previous).
2. I then unchecked the scale division and clicked apply as shown in image. The legend then showed 14 divisions.
3. I then rechecked the unchecked scale division and clicked apply. The legend now displays the full range (i.e 15 divisions).
Regards
Dane
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
The scale on the viewer is displayed "in full" for up to 14 divisions. If you enter a larger value the display of the legend on the screen is limited to lower number of colors but on the map itself there are as many colors as specified e.g. 100.
Artur Kosakowski
