Robot Structural Analysis Steel connection definition for American Code?
RuySTC
RuySTC
Hi Guys,
i just have some inquiries about the steel connection definition of Robot..
is there a version which supports American Code(AISC) for Steel Connection?
upon checking, only Eurocode 3, Poland, and France are only options for Steel connections in Robot..
will appreciate your response whether its possible to do analysis using american code or not.
or you have some workarounds on this issue..
thank you..
Artur.Kosakowski
Autodesk Support
Autodesk Support
US code is not supported in the steel connection design module in Robot. As  the workaround you may export whole structure or just only these elements you want to design connections for with internal forces to Advance Steel and design them there as demonstrated during the RSA to AS interoperability webinar which recoding is available from:
http://forums.autodesk.com/t5/robot-structural-analysis/robot-structural-analysis-webinars/td-p/5523...
Artur Kosakowski
