I've made first project using this software and I have unusual problem occuring. First, after adding all of the loads on my structure, the file crushed every time I tried to open it.
I tried opening in "Safe mode", same effect.
After sending automatic raport to your site, I got the message that issue is unknown, but i can install SP6, and I did so.
The file started to work again, but another problem occured, there were no combinations for Loads (just like they've been wiped out):
robot.jpg shows the problem, SGU, SGN means standard Servicability and Load Capacity checks from Eurocode.
A the beginning load combinations were normal and I could define from the list which is now empty.
Moreover any option of combinations (automatic, hand-made) have "estimated number of combinations : 0"
Things i have done so far:
- Reinstalled ROBOT software, then sp6 - no effect
- Tried removing last loads I've made (before the file stopped working ) - no effect
- Tried changing the base standard to make combinations - no effect
- Looked if the *rgl files responsible for combinations aren't missing, they seem to be on their place.
I have no ideas what to do now. Any help would be appreciated.
Yours Faithfully,
Pawel Swieciak
