Robot structural analysis_Generate model destroys calculation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
my model did work and the results from the calculation were right. Then I went from calculation methods to structural model and generated a calculation model from that:
Afterwards the calculation went completely wrong. There were moment(My) forces where a release without moment bearing was defined:
Before, everything was alright and it seems afterwards the software is not more able to do a normal clalculation for the whole structure.(Even levels below without defined releases were affected, so there was also this picture with the moment like a triangle).
My question: Is there a possibility to undo this step? The normal way to undo steps did not work..
Furthermore what is the problem?
See model attached.
Thank you in advance!
