Robot Structural Analysis 2025-Close Excel Dynamo
stefanyC6JZ7
stefanyC6JZ7
Hello everyone,
I am trying to use RSA2025 to run dynamo scripts. I am trying to close Excel with the script but I get the following error:
Please find the code from the script below :
import sys
import clr
import System
clr.AddReference('Microsoft.Office.Interop.Excel, Version=15.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c')
from Microsoft.Office.Interop import Excel
from System.Runtime.InteropServices import Marshal
def excel_close(lst_namefile):
    xlApp = Excel.Application(Marshal.GetActiveObject("Excel.Application"))
    print(xlApp)
    allWorkbooks = Excel.Workbooks(xlApp.get_Workbooks())
    print([x for x in allWorkbooks])
    lst_WkbsName = [Excel.Workbook(x).get_Name() for x in allWorkbooks]
    for namefile in lst_namefile:
        if namefile in lst_WkbsName:
            Tesluiten = Excel.Workbook(allWorkbooks.get_Item(namefile))
            Tesluiten.Close()
    xlApp.Quit()
toList = lambda x : x if isinstance(x, list) else [x]
OUT = excel_close(toList(IN[0]))
 Could you please help me solving this issue?
Best regards,
Stefany
1234eddie
Hi All,
just to add a little bit extra information.
Here is the full error message
Message
FileNotFoundException : Unable to find assembly ‘Microsoft.Office.Interop.Excel, Version=15.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c’. at Python.Runtime.CLRModule.AddReference(String name)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
at System.Reflection.MethodBaseInvoker.InvokeDirectByRefWithFewArgs(Object obj, Span`1 copyOfArgs, BindingFlags invokeAttr) [’ File "
Version Dynamo RSA 2022 runs fine.
Version Dynamo RSA 2025
I hope @okapawal @Rafal.Gaweda or maybe others can have a quick look at this?
Many thanks in advance
Gr Edward
okapawal
@1234eddie
Can you check or post it n the Dynamo Forum ?  Dynamo (dynamobim.com)
It is rather Dynamo core issue.
Waldemar Okapa
Sr Product Owner
