Robot Structual Analysis for Mac?
Hi all,
is there a possibility to install "Robot Structual Analysis" on a MacBook Pro? From all versions I can choose there is only Windows as a possible system shown. I have a student account on AutoDesk.
Thank you for your help!!
Romanich
Robot is only for Windows.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You may try to run Robot on a Windows emulator on Mac and check if this makes the trick. Some time ago we were informed by one of the RSA users that it worked for him however Autodesk has never made such tests.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
zeeblake
I'm using Robot 2019 update 1 under VirtualBox on MacOS Sierra 10.12.6. The VM is Windows 7 SP1 with all updates applied until yesterday. I have the 3D acceleration enabled, and it seems to run fine. But however, note that Robot needs resources: You need a Mac with preferably 16GB RAM (so that you can assign 8GB to the VM) and a relatively recent CPU, with preferably a good GPU as well.
As I said, it seems to run fine, but if I notice any issues, I'll report back.
