Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Robot Steel API - Member definition parameters
11 REPLIES 11
Message 1 of 12
1936 Views, 11 Replies
I'm trying to define members parameters, using Robot Steel API, to design a bar structure steel with EN1993-1.
I have seen the document "Robot API Steel Design" but I can’t do it. It’s possible provide a complete example to "Visual Basic -Microsoft Excel" for a “Bar” type?
11 REPLIES 11
Message 2 of 12
Rafal.Gaweda
Look closer at paragraphs 4.4.1 and 4.4.2 in mentioned doc.
Examlpe below
Set all \ required RDimMembParams in place where you cae see commented dots in code below
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
    RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:1992"
    Dim RLabel As IRobotLabel
    Dim RdimLabelData  As IRDimMembDefData
    Dim RDimMembParams As IRDimMembParamsEC3
        Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "My Label")
        Set RdimLabelData = RLabel.Data
        RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, 100
        RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200
        RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_X, 300
        RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_Y, 400
        Set RDimMembParams = RdimLabelData.CodeParams
        RDimMembParams.BuckLengthCoeffY = 10
        RdimLabelData.CodeParams = RDimMembParams
        RobApp.Project.Structure.Labels.Store RLabel
Rafal Gaweda
Message 3 of 12
Thank you!
Message 4 of 12
in reply to: Rafal.Gaweda
When I run the Macro in Excel, it return an error:
Run-time '13'
Type mismatch
It occurs on line:
Annex image with the error.
Thank you!
Message 5 of 12
Rafal.Gaweda
Wrong Params.
    RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:2005"
    Dim RDimMembParams As IRDimMembParamsE32
Rafal Gaweda
Message 6 of 12
Ok! Already works! Thank you!
Message 7 of 12
At the moment, I have defined the member type. What remains now is to assign the type of member to the respective bar, in other words, assign the type "My Label" to a bar 1 and 2, for example. How do this? You can send an example?
Thank you.
Message 8 of 12
Rafal.Gaweda
Like for all labels
for one \ given bar number
Dim Rbar As RobotBar
Dim BarCollection As RobotBarCollection
RobApp.Project.Structure.Bars.Get(bar_number).SetLabel I_LT_MEMBER_TYPE, "My Label"
'or
Set Rbar = RobApp.Project.Structure.Bars.Get(bar_number)
Rbar.SetLabel I_LT_MEMBER_TYPE, "My Label"
for bar collection
Set RobotBarCollection = .........
For i = 1 To BarCollection.Count
BarCollection.Get(i).SetLabel I_LT_MEMBER_TYPE, "My Label"
Next i
Rafal Gaweda
Message 9 of 12
Dear all,
I tried to implement the code below with the corrections made and wasn't able to do it.
An error appears in the line that sets Member Parameters :
Sub A_MemType()
        Set RLabel = RobApp.Project.Structure.labels.Create(I_LT_MEMBER_TYPE, "My Label")
        Set RdimLabelData = RLabel.data
        RobApp.Project.Structure.labels.Store RLabel
End Sub
 Thanks in advance.
Message 10 of 12
Artur.Kosakowski
Try:
Sub A_MemType()
           RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "EN 1993-1:2005/AC:2009" ‘ "ENV 1993-1:2005"
           Dim RDimMembCodeParams As Object ‘IRDimMembParamsE32
           RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, 100 RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200
           RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_X, 300 RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_Y, 400
           Set RDimMembCodeParams = RdimLabelData.CodeParams
           RDimMembCodeParams.BuckLengthCoeffY = 10
           RdimLabelData.CodeParams = RDimMembCodeParams
    End Sub
Artur Kosakowski
Message 11 of 12
in reply to: Artur.Kosakowski
Thanks Arthur. It worked perfectly.
Message 12 of 12
Hello @Artur.Kosakowski,
how to translate  Dim RDimMembCodeParams As Object in C# ?
Thank you in advance,
Regards
Louis
Technology Administrators
