Robot problem modelling an elliptic shell structure
Hi, I am new modelling on Robot.
I have been trying to model an Elliptic shell structure of concrete, 6 cm thickness in Robot for my thesis project.
The front elliptical arc has a different shape that the back one, also I have an inclination at the bottom part.
I have tried to transfer the model from AutoCAD to Robot but I only get a series of dots and I cannot get the surface.
Do you guys have any idea how to do it?
Jorge Vazquez
1.- Autocad Shell.PNG5.- Inclination of the roof.PNG2.- Dots obtained from Autocad shell in Robot.PNG
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
I have recorded this type of structure creation procedure (see attached link).
Main steps presented in recording (predefined grids were used to control geometry)
  • bottom contour lines definition
  • arcs definition (arc discretization and bar creation options on)
  • arc grouping
  • grouped arcs deformation (to form elliptic shape)
  • groups exploding
  • panel definition (using list of object method)
  • panel mesh parameters definition (Coons method, user division definition)
  • panel thickness definition
  • unnecessary bars deleting
  • supports definition
  • calculation
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
Thank, you very much answer.
Here is the model I did with your solution.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for sharing. Good luck with your project
Krzysztof Wasik
