Robot frame with truss calculation
Hello. I want to calculate a frame which is made of two collumns and truss (picture 1). To calcualte roof beams as a truss you need to go to Geometry/Additional Attributes/Advanced Bar properties and check whem as truss or is there anything else what needs to checked?
Another question is about supports. I want to connect collum using angle and screws and to connect truss with column also using screws (picture 2). Does this count as pinned support, or should a set it up manually? If yes, could you give an advice what to do?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
1. Try to set the posts and diagonals as truss bars keeping the chords as 'standard'bars (with bending moment transfer)
2. IMHO they are more moment transfer connections than pinned ones.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
