Robot doesn't use the entire rebar length
I am designing a 14m beam with 4 spans. My maximum rebar length is 9m but when I use provided reinforcement I realise the software doesn't use the full 9m even when the reinforcement is needed along the entire length. It rather breaks them into small bits like 2m, 3m etc. How do I make it use the entire 9m without breaks?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the rtd file with this beam?
Artur Kosakowski
Ok
I am attaching it.
Check beam 68 as an example.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The reinforcement generation algorithm tries to split bars at the locations of the zero bending as the priority. If you want longer bars you can adjust them in the way shown below:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
I tried it and got this error.
I dont get what the error means.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
If you have a closer look you can see that you actually selected two parallel reinforcement bars rather than two co-linear ones. Before selecting rebars switch to the Detailed tab of the reinforcement table visible under the graphical viewer wit beam reinforcement and then select two co-linar top reinforcement bars.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Ok
I got it now
