Revit – Robot interoperability and Results Connect , Robot API, Dynamo
Nissar19
Nissar19
Hi Artur.Kosakowski!
I wonder if it is possible to get excel shett of Revit – Robot interoperability and  Results Connect , Robot API, Dynamo?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Nissar19
I'm sorry but I don't have such materials. You may want o check the recordings and handouts from the corresponding Robot webinars.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Nissar19
Thanks a lot:)
