Robot doesn't save RC column design buckling parameters
eruchirapsl
eruchirapsl
Robot doesn't save the buckling parameter for RC columns. This is a bug and please fix it. if you run the analysis again and when you check the columns again for updated results it resets automatically
Romanich
Hi @eruchirapsl , please specify Robot's version
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
eruchirapsl
Robot 2022 v35.0.1.8274(x64) Licensed
As an example I set values for both buckling axes earlier and here what I got after I have run the analysis again . I just ran analysis without any structural or load modification
. Not only for a particular column, but for all the columns, it was changed.
