Robot does not consider crack for RC column
Message 1 of 12
Thank you Artur,
i solved the problem by calculating the model just with SLS combo.
I also have a problem with a column. The column is just subjected to a tensile strain and the results give me both steel and concrete reacting and zero crak, thought the concrete tensions are higher then the concrete tension resistance. Is it possible that Robot does not considere crack for RC column?
Thank you.
Giulio
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You need to enable this  verification in the way shown below:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 3 of 12
I have a column with 1 m diameter, i made a SLS combo with a tension axial force of 2900 kN and a longitudinal  circular reinforcement with n°24 phi 25 bars. The crack width cannot be calculated cause internal force result to be zero. In the attached immagine i have reported the results.
Message 4 of 12
Message 5 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the file with this column?
Artur Kosakowski
Message 6 of 12
I'm trying to attach it but the forum message doesn't let me send it.
Message 7 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the screen capture from this message?
Artur Kosakowski
Message 8 of 12
I attach the file like this:
1.pngclick "post", and the following situation appears:
Message 9 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you check if you still have the same issue with attaching the file please?
Artur Kosakowski
Message 10 of 12
Yes, there is the same issue, i'm still trying to attach the robot model.
Is it possible that Robot doesn't consider cracks in column design  or check?
Message 11 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
If the check is enabled then it is verified.
Artur Kosakowski
Message 12 of 12
Thank you @Artur.Kosakowski
