Good Evening,
I want to use c ++ with Robot API.
I pasted into the code: #import "C: \ Program Files \ Autodesk \ Autodesk Robot Structural Analysis Professional 2019 \ System \ Exe \ robotom.tlb" rename_namespace ("Robot_API") using namespace Robot_API;
but i can't create a struct RobotApplication.
When I debug, I have a message: error C2079: 'Robot' uses undefined struct 'Robot_API :: RobotApplication'
structure, classes and functions are available in the expansion, but I cannot even create the initial structure.
Please help, Thank you in advance.
Same subject, look at:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/c-api-help/td-p/9091994
Good afternoon,
unfortunately these links do not explain my problem.
@Artur.Kosakowski @Rafal.Gaweda
can you solve this problem?
Have you experience with c ++ with robot api?
What could be the reasons?
Some say it's the best. I do not know if it's true.
So far, this is the only programming language I know a bit.
Do you suggest Dynamo or excell, C#?
Yes. C#/Python/Dynamo/VB/VBA but it depends on the software you want to interest and the size of what you want to do.
The simplest language is not the fastest and most complete for OOP.
Using C # or Python with Visual Studio are more functional for me.
For small programs that do not require the use of large data, VBA and presentation in Excel is better, and does not require authorizations from the IT department. For bigger, There is the possibility with other langage to create specific functions and to use them with DLLs in VBA or Robot.
Dynamo is great for graphicaly scripting features without expanding too much, but seems less harmonious when it comes to putting them together.
It depends of you also. The time you spend there and the plans you have.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/rsap-api-language/m-p/7987527
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-developpment/m-p/7791340
