ROBOT API - Three and four point trapezoidal loads
a.gonzalezY3KSY
a.gonzalezY3KSY
I am Alejandro, a structural analyst of lightweight façade structures. A few weeks ago I started to use the Robot API to automate the creation of simple models.
I have problems when creating a trapezoidal load defined by more than two points (three or four). I write the code I am using:
Dim CaseWind As RobotSimpleCase
Set CaseWind = s.Cases.CreateSimple(3, "WIND_LOAD1", I_CN_WIND, I_CAT_STATIC_LINEAR)
Uniform = CaseWind.Records.New(I_LLT_BEAM_LOAD_TRAPEZOIDAL3)
Set LoadRecord = CaseWind.Records.Get(Uniform)
LoadRecord.SetValue I_BTRV_PX1, 0
LoadRecord.SetValue I_BTRV_PX2, 0
LoadRecord.SetValue I_BTRV_PX3, 0
LoadRecord.SetValue I_BTRV_PY1, 0
LoadRecord.SetValue I_BTRV_PY2, 1000
LoadRecord.SetValue I_BTRV_PY3, 0
LoadRecord.SetValue I_BTRV_PZ1, 0
LoadRecord.SetValue I_BTRV_PZ2, 0
LoadRecord.SetValue I_BTRV_PZ3, 0
LoadRecord.SetValue I_BTRV_X1, 0
LoadRecord.SetValue I_BTRV_X2, (longitudTrav - A)
LoadRecord.SetValue I_BTRV_X3, A
I have read the API documentation but have not been able to find the answer.
Thank you very much in advance.
Stephane.kapetanovic
hi @a.gonzalezY3KSY
I_LLT_BEAM_LOAD_TRAPEZOIDAL3 doesn't exist in IRobotLoadRecordType
I_BTRV_PZ3 and  I_BTRV_X3 doesn't exist in IRobotBarTrapezoidaleRecordValues
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
hi @a.gonzalezY3KSY
here after sample code for a trapezoidal load with 3pts
Sub Add_New_BarTrapezoidal_3Pts()
  Dim Robapp As RobotApplication
  Dim NewRecord As RobotLoadRecordBarTrapezoidal
  Dim A As Double, B As Double
  Set Robapp = New RobotApplication
  Set CaseWind = Robapp.Project.Structure.Cases.CreateSimple(3, "WIND_LOAD1", I_CN_WIND, I_CAT_STATIC_LINEAR)
  A = 0.25: B = 0.5
  Set NewRecord = CaseWind.Records.Create(I_LRT_BAR_TRAPEZOIDALE)
  NewRecord.PointCount = 3
  With NewRecord
    .Objects.FromText "1"
    .PointCount = 3
    .SetPoint 1, 0, 0, 500, A
    .SetPoint 2, 0, 0, 1000, B
    .SetPoint 3, 0, 0, 500, 1 - A
    .SetValue I_BTRV_RELATIVE, True
  End With
  Robapp.Project.ViewMngr.Refresh
  Set Robapp = Nothing
End Sub
Best regards
in addition
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-add-loads-to-a-bar/m-p/7855485
a.gonzalezY3KSY
Thank you very much for your answers Stephane. I was used to using robot manually with the 4 point trapezoidal loading option. I had not thought of generating several individual 2-point ones.
I will bother you soon with more problems 😅
Best regards
