Robot API SDK/ examples
Message 1 of 8
I'm intrested in leraning Robot API . Where can I find something like SDK or full documentation of the API ?
I'd be very grateful for a link because I can't fi nd it on my own.
Thak you fory your help.
Tomasz Chacuk
Replies (7)
Message 2 of 8
The documentation is inculded in the install of SDK.
C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\SDK
Message 3 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
This can be helpfull:
http://www.robobat.com/n/ros
You may also searcg this forum for text API or SDK to see many hints \ examples.
Rafal Gaweda
Message 4 of 8
Thank you. Some time ago I came into this page, but I couldn't find it agan.
Message 5 of 8
Dear RG
When I check link
then messenger show
Site temporarily unavailable.
Connection timed out - please try again.
thanks
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
When I check link
then messenger show
I know. We are checking this site.
API tutorial I sent is the same - run it from your hard disk.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Tutorial/td-p/3939601
Rafal Gaweda
Message 7 of 8
xavier_durieux
Hello.
Is that SDK location (C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2016\SDK) still valid ?
I can't find it ; I only have 'System' and 'Setup'...
Message 8 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Have you installed SDK?
Rafal Gaweda
