Robot API Modal Analysis -Selecting specific mode
GGB.BHB
Message 1 of 11
GGB.BHB
Hi
I am using the Robot API to extract modal data directly to Excel to save time.  My code selects the modal load case as below
RobotSelection LoadCase_selection = robot.Project.Structure.Selections.Create(IRobotObjectType.I_OT_CASE);
LoadCase_selection.AddText(Convert.ToString(ModalLoadCase));
result_params.Selection.Set(IRobotObjectType.I_OT_CASE, LoadCase_selection); //Setting Load Case to ModalLoadCase
Is there a similar way to call a specific mode? My code currently scrolls through rows of results till it finds the correct mode as such (which is very slow as I have many mode shapes)
while (query_return != IRobotResultQueryReturnType.I_RQRT_DONE)
query_return = rserver.Query(result_params, row_set);
bool ok = new bool();
ok = row_set.MoveFirst();
while (ok)
int curr_mode = (int)row_set.CurrentRow.GetParam(IRobotResultParamType.I_RPT_MODE);
if (curr_mode == Mode)
Many Thanks
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Public robot As RobotApplication
Private Sub CommandButton2_Click()
Dim RobApp As New RobotOM.RobotApplication
Dim Res As IRobotResultQueryReturnType
Dim RobResQueryParams As RobotResultQueryParams
Dim RobResRowSet As New RobotResultRowSet
Dim SelNode As RobotSelection
Dim SelCas As RobotSelection
Set SelNode = RobApp.Project.Structure.Selections.Create(I_OT_NODE)
Set SelCas = RobApp.Project.Structure.Selections.Create(I_OT_CASE)
SelNode.AddText ("all")
SelCas.AddText ("2")
Set RobResQueryParams = RobApp.CmpntFactory.Create(I_CT_RESULT_QUERY_PARAMS)
RobResQueryParams.Selection.Set I_OT_NODE, SelNode
RobResQueryParams.Selection.Set I_OT_CASE, SelCas
RobResQueryParams.SetParam I_RPT_MODE, 2
RobResQueryParams.ResultIds.SetSize (3)
RobResQueryParams.ResultIds.Set 1, I_EVT_MODAL_EIGENVECTOR_UX
RobResQueryParams.ResultIds.Set 2, I_EVT_MODAL_EIGENVECTOR_UY
RobResQueryParams.ResultIds.Set 3, I_EVT_MODAL_EIGENVECTOR_UZ
Dim v As Double
Do
 Res = RobApp.Project.Structure.Results.Query(RobResQueryParams, RobResRowSet)
Dim ok As Boolean
ok = RobResRowSet.MoveFirst()
While ok
UX = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(1))
UY = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(2))
UZ = RobResRowSet.CurrentRow.GetValue(RobResRowSet.ResultIds.Get(3))
MsgBox UX, UY, UZ
ok = RobResRowSet.MoveNext()
Wend
Loop While Res = I_RQRT_MORE_AVAILABLE
End Sub
Rafal Gaweda
Message 3 of 11
GGB.BHB
Thanks Rafal for your response.
I am working in C# and the one line I believe I was missing was
which I converted to
result_params.SetParam(IRobotResultParamType.I_RPT_MODE,3);
Unfortunately this doesn't seem to work to reduce the data flowing through.  If I set the mode to 3 (as above) I can still get the results for Mode 26
using the call later on in the script.
if (curr_mode == 26)
Any suggestions?
Many thanks
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
You are right. This line should work but it does not.
You need to add mode check, as you did in code, for now.
It is needed to be corrected in software
You may try RobotNodeDisplacementServer.DynValue(...) or RobotAdvancedResultServer.Eigenvectors.Value()  but it might be slower than queryparams
Rafal Gaweda
Message 5 of 11
GGB.BHB
Thank you
Gillian Browning
Message 6 of 11
hvdsidf
Bonjour,
I have tried to test your code, but it doesn't work in the line:
It seems that you have declared the variant "Dim RobResRowSet As New RobotResultRowSet", it is not SET, isn't it?
The message error for the variant "RobResRowSet" is : <Variable objet ou variable de bloc With non définie>
Thanks in advance for your reponse.
Structure Ile-de-France
Message 7 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
RobApp.Project.Structure.Results.Query does not work in VBA nor is other 32 bits builds.
You need to use VB 64 bits or C# 64 bits to create dll or exe
Rafal Gaweda
Message 8 of 11
hvdsidf
Hi Rafal,
I'm a amateur "programmer".
If I understand well your message, you mean that I need to have VISUAL STUDIO?
Best regards,
HVD
Message 9 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Exactly
Rafal Gaweda
Message 10 of 11
rwemay
Hey Rafal,
Is the filtered mode selection fixed/enabled in the API query method now?
thanks,
Rob
Message 11 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @rwemay
I am sorry, I am not aware of any fixes there.
Rafal Gaweda
