Partial Seismic Analysis - 'greyed out' structure is not editable
ALJohns
ALJohns
Hi Guys
I am considering a bridge crossing 4 rail lines.
In addition to standard loading (Dead, Live, Wind, Earthquake, Thermal etc.), I am considering a derailment case. The bridge has 2 central piers, and during the derailment case, it is assumed the central supports are compromised and the bridge spans across the 4 rail lines (with reduced live loading).
To analyse this, I have set up 2 similar models: The first is for checking all of the standard loads, the second is for checking the case with reduced supports (considering vertical loads only). My problem occurs when I set up seismic loads and define stories. I want to exclude the second model from seismic loading, but when I do, the second model is 'greyed-out' and is not editable (even for the standard load cases).
I have attached a screenshot with more details.
Thanks for your help.
Aaron.
Artur.Kosakowski
Autodesk Support
Autodesk Support
I suggest defining the models in the separate files.
Artur Kosakowski
ALJohns
Thank for the response Artur.
I was hoping to keep the two models in one file so that I can group similar members and run the steel verification and design for both models at the same time.
Can you explain the purpose of 'stories - advanced options' if it isn't used to isolate the extent of the seismic analysis?
Also, why is the structure 'greyed-out' for the standard load cases? Is this a bug, or is it indicating a modelling error?
Aaron
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach the file? I initially assumed that you defined the response spectra analysis but perhaps you actually used the Equivalent Lateral Force Method instead?
I assume you just have the story filer applied.
Artur Kosakowski
