Robot 2022 unable to show moving loads
t_ng
t_ng
I am not sure if anyone else here is experiencing the same problem. After installing the 2022 version, I realised that Robot is unable to show "Moving Loads" in the model. It still calculates forces with the applied moving loads, just that it doesn't show it in the model anymore.
Cheers.
CaioSaporito
Hi @t_ng !
Try this:
Caio
t_ng
Hi @CaioSaporito
Thanks. "Forces generated automatically" shows the load after distribution. I normally just click the "Moving loads" and it shows the applied load "before distribution".
This problem only occur with version 2022. I had no problem at all before that.
Would you be able to try just clicking "Moving loads" and see if it shows the loads before distribution? Please try with version 2022.
Thanks a lot.
Tom
okapawal
Hi @t_ng
You are right, the vehicle load should be displayed with "Moving loads - vehicle".  This is a bug that it is displayed with "Forces generated automatically" in version 2022.
We have already noticed this and it will be corrected in incoming Hot Fix for 2022 release.
Waldemar Okapa
Sr Product Owner
okapawal
This issue has been corrected with Robot Structural Analysis 2022 Hotfix 1.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-structural-analysis-2022-hotfix...
Waldemar Okapa
Sr Product Owner
