ROBOT 2016 - Detailing calculation ofbeams of reinforced concrete
My name is Nuno Ferreira and I am of Civil Engineering Master's student.
Inform what is happening a problem in Robot Structural Pro 2016 program, in particular calculation of Concrete Beams:
1- The diagram efforts appears complete before the selected element calculation (see picture 1 ).Image 1.jpg
2 After entering the detail table and customization of steel armor, the same diagram is shown incomplete. Fails to display the line for custom armor area, ie the area of bending and beam drift is no longer displayed on the tab of the efforts diagrams (see image4).Image4.jpg
Thank brief answer to be able to continue working and continue to enjoy this work tool.
Best Regards,
Nuno Ferreira
nferreira.eng@gmail.com
serial number: 900-59453577
License id: RSAPRO_F_S
Artur.Kosakowski
Autodesk Support
Autodesk Support
When in the typical reinforcement you set rebars with no hooks their type is not correctly recognized. The simple solution is to set them with e.g. 90 deg hooks and then edit them after they are generated as shown on the movie:
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Corrected in RSA 2017.
Artur Kosakowski
