Robot 2013 crack width in column according to Eurocode
Romanich
Mentor Mentor
Message 1 of 13
Romanich
Hi Artur, I tried to see crack width in column according to Eurocode, but in table results always zero.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Replies (12)
Message 2 of 13
Rafal.Gaweda
Autodesk Support
Autodesk Support
Have you defined SLS case?
Have you enabled SLS design?
Rafal Gaweda
Message 3 of 13
Romanich
Hi Rafal
I expected to see crack width in Required reinforcement results table:
Roman Zhelezniak
Message 4 of 13
Rafal.Gaweda
Autodesk Support
Autodesk Support
Not implemented for this module.
Only in Provided Reinforcement of Columns.
Rafal Gaweda
Message 5 of 13
Gents,
Hi. I can not seem to get my version of ROBOT (Structural Analysis Professional 2011) to check  a column for crack width. All I can seem to check are ULS cases, no SLS ones! In the screenshot belo you can see the "advanced" button (which I think enables checking for cracks) is missing. Is this feature not available in my version of ROBOT or am i missing something?
Jon
Message 6 of 13
Romanich
Yes, this feature available only in 2013 version of Robot.
Roman Zhelezniak
Message 7 of 13
Rafal.Gaweda
Autodesk Support
Autodesk Support
As you may see from thread subject it is related to ARSA 2013.
SLS check for Eurocode columns in implemented in v.2013.
Rafal Gaweda
Message 8 of 13
To not make a new topic. I am trying to calculate a RCC column according to Russian Standard SP 52-101 (or SNiP 52-01). It is not possible to make crack checking for column elements, is it?
Message 9 of 13
Rafal.Gaweda
Autodesk Support
Autodesk Support
No.
Rafal Gaweda
Message 10 of 13
Thank you for the reply. But how we can proceed then?
Message 11 of 13
Rafal.Gaweda
Autodesk Support
Autodesk Support
Use Eurocode or calculate it manually.
Rafal Gaweda
Message 12 of 13
Thank you, but Eurocode is not valid in Russia. Manually - ok.
Will this be added in the nearest furure?
Message 13 of 13
Rafal.Gaweda
Autodesk Support
Autodesk Support
