Ring foundation with supports
netvennoot
netvennoot
Hey fellow Robotters!
I've been stumped by the need to design a "ring" foundation with supports for a shipping container.
The ring is to be 1,8m below ground level, 300mm thick and 600mm wide about the same size as the footprint of the shipping container.   From this ring foundation I need 4 beams/columns on the corners for the container to rest on.
See attached drawing.
How do I go about designing this rc element?
Is it possible to do this in Robot?
teixeiranh
-Have you done this previously?
-Yes.
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
netvennoot
Thank you, can you explain how to do it, please?
teixeiranh
You need to define a slab on grade with all the parameters and then perform rebar design via required reinforcement.
If you check my channel I have some examples on how to do it.
