Message 1 of 12
04:56 AM
- Mute
- Permalink
- Report
I have a question to "Rigid Links". What is the rule for the distribution forces from master node to the slaves nodes. Because I did a simple test for transfer Moment and Force (figure under), I blocked the UZ for the slaves nodes.
It is looks like depending from geometry of the slaves nodes.
I also tested an centric and eccentric master node position in terms to the columns.
Answer is important when we use "rigid links" for example to connect beam element and shell element.
