Rigid Links and Logical Lists in API
Romanich
Mentor Mentor
Romanich
I have found some awkward bug (or it is a feature?) in the Robot API. If Robot GUI has working language different from English (for example Russian), the code will not work as it should:
Dim RNRLS As RobotNodeRigidLinkServer
Set RNRLS = RobApp.Project.Structure.Nodes.RigidLinks
RNRLS.Set 1, “2to8”, "RLink"
Only one rigid link will be created – to node 2, because logical lists in Robot are localized (I thought they should not depend from language through API).
To solve this issue we can try to do like this:
Dim Robapp As New RobotApplication
Dim CurrLang As Long
CurrLang = Robapp.Preferences.GetLanguage(I_L_WORK)’get current language of Robot
Robapp.Kernel.Preferences.SetLanguage I_L_WORK, 1 ’switch to English (code 1)
Robapp.Kernel.Preferences.SetLanguage I_L_WORK, CurrLang ’switch back to original language
And everything is awesome!
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Rafal.Gaweda
Autodesk Support
Autodesk Support
Of course it is like that.
All text keywords (in case of selections "to", "by") depends on selected language
See this macro with my way of dealing with some keywords
http://forums.autodesk.com/t5/robot-structural-analysis/api-macro-for-highlighting-nodes-with-instab...
example:
lang = Robapp.Preferences.GetLanguage(I_L_WORK)
    detected = Switch(lang = 1, "detected at node", lang = 44, "detected at node", lang = 48, "w węźle", lang = 33, "au noeud", lang = 34, "en el nudo")
Rafal Gaweda
