- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have found some awkward bug (or it is a feature?) in the Robot API. If Robot GUI has working language different from English (for example Russian), the code will not work as it should:
Dim RNRLS As RobotNodeRigidLinkServer Set RNRLS = RobApp.Project.Structure.Nodes.RigidLinks RNRLS.Set 1, “2to8”, "RLink"
Only one rigid link will be created – to node 2, because logical lists in Robot are localized (I thought they should not depend from language through API).
To solve this issue we can try to do like this:
Dim Robapp As New RobotApplication Dim CurrLang As Long CurrLang = Robapp.Preferences.GetLanguage(I_L_WORK)’get current language of Robot Robapp.Kernel.Preferences.SetLanguage I_L_WORK, 1 ’switch to English (code 1) Dim RNRLS As RobotNodeRigidLinkServer Set RNRLS = RobApp.Project.Structure.Nodes.RigidLinks RNRLS.Set 1, “2to8”, "RLink" Robapp.Kernel.Preferences.SetLanguage I_L_WORK, CurrLang ’switch back to original language
And everything is awesome!
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
