Rigid link
Rigid link
Message 1 of 8
Rigid link
I'm doing a metal roof with trusses and in front will put a ledge 6 meters tied to the lattice height 2m. Can I say that this link is a rigid link locked in all directions?
Thank you
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you post  a picture of the structure and indicate the intended rigid link so that it is easier to understand your description?
Artur Kosakowski
Message 3 of 8
I put the file
in the connection between the platen and the cover
Message 4 of 8
Rafacascudo
Your rigid link is rigid for translations. All rotations are free
Rafael Medeiros
Message 5 of 8
But is it correct to admit this situation?
Message 6 of 8
Rafacascudo
Depends on your real life connection between the 2 members
Rafael Medeiros
Message 7 of 8
sorry I did not specify, yes it depends on the connection between structures, but what I wanted to say is if I can consider a rigid connection, if this is the concept of the command?
Message 8 of 8
Rafacascudo
Yes you can consider it a rigid connection for translations
Rafael Medeiros
