Error: no material
Error: no material
Error: no material
When I run the calculation, it gives the warning 'no material'. However, as far as I can tell a material has been assigned.
Muhammed.OPERA
Hi @Anonymous
Try to use another thickness for the panels or check the panel thickness you have assigned, it seems that something is missing (maybe thickness) as you can see in the object inspector all thickness prop. are N/A.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
Please check this article:
ROBOT - error: 'no material' after local meshing of a panel
Please let me know if this article contains the solution you are looking for and if you searched for  such solution first as well as if you think it needs any improvement to be found easier or if the solution is easy enough to be understood so that I could improve it. Thank you.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
