Rigid link primary node
Lembartassimas
Message 1 of 1
Lembartassimas
Is it possible to make a rigid link that transmit forces only to the secondary nodes like in example (2 nd. picture) (in that picture forces are distributed manually to the nodes)? Because when i select center as primary node and circle as secondary nodes, i do get that it also affects the center node).
Replies (0)
